No Jumper?
Dougjwjr
I'm currently building a computer (my first build). I got an oem HDD (wd 640 se16), from newegg, and I notice it doesnt have a jumper. I dont know if there should have been one with the hard drive, someone told me there should be some with the motherboard but I cant find any. (mobo's an evga 680i 122 nf68)
Yea sata drives don't have your master slave setup as the old ata drives do. You just run a sata cable from the drive to the motherboard.
o.o, great, I'm not missing that then..
New question... there are 3 things on my drive... sata plug, power, what's the 8 pin connector if it's not for a jumper
the SATA power cable? Its not the standard molex, SATA has one designed for hot swapping, which a molex plug is not. You can use either the molex or the SATA power for the actual power connection, some drives have both.
The sata power plug is the same L shape as the SATA signal connection, but its wider.
http://www.westerndigital.com/global/images/products/bck/wdfDesktop_CaviarBlue_SATA16.jpg
The plug on the right is a jumper block for some advanced options (outlined in the PDF linked above). Ignore it.
