Title says it all.
While both my AVM Fritz!DSL WLAN Box 3030 (not using WLAN though) and my AVM Fritz!DSL SL pci card (both very popular in Germany) install correctly, everytime i try to connect to the internet i get "Failed to connect". Diagnosing the problem reveals there is no problem (surprise!).
I've read some problems about marvel ethernet controllers, but not with AVM (are they using marvel chipsets too?).
Connecting to other computers works like a charm. My only problem is internet connection.
I'm using the latest drivers for both the devices (which are actually recommended XP drivers from AVM itself). Also, this didnt work with previous vista builds either.
Anyone has the same problems? Any suggestions?
I've tried this solution described in this post http://www.hardforum.com/showthread.php?t=1093484 , but its still a no go.
Any help would be greatly appreciated! Thanks!
