Mad_Murdock
- Apr 29, 2015
The weird thing is, the 'No display' issue is random. At times, I will see the MSI logo, POST codes, then the screen goes black once Windows boots; other times, Windows comes up fine. Another issue is, sometimes when I resume from sleep mode, I get a black screen, I can still hear Windows system sounds, however, so I know Windows is still up and running.
I have uninstalled Nvidia drivers, used driver cleanup utilities, then installed new/older/beta drivers, none of which resolve the issue. I have disabled all overclocking and used default BIOS settings. I have ensured my mobo and video card BIOS' are up to date. All other drivers are up to date. I have tested both cards individually; stress tested with Furmark, without error. I have swapped video cards/PCIe slots. I even upgraded my 750w (to 1300w) PSU in order to ensure I had enough power to supply the SLI setup; issue persists with both PSUs. I have used three different SLI bridges. Tried DVI, HDMI, and DP cables. Tested with 3 separate monitors. Ensured onboard video is disabled.
If I disable the SLI option in Nvidia control panel, the issue goes away... but, what's the point of having two video cards if I have to disable SLI? Any ideas, because I'm all out of them.
Specs (all stock settings):
OS: Windows 8.1 (up to date on patches/fixes)
CPU: Core i5 4670k
Mobo: MSI Z97 Gaming 5 (Firmware v1.9)
GPU 1: MSI GTX 970 Gaming 4G
GPU 2: MSI GTX 970 Gaming 4G
PSU: EVGA SuperNOVA 1300G2 (1300 watt, 80plus Gold)
Memory: Corsair Vengeance Pro 16GB (1866)
HDD: Crucial SSD 120GB, Sandisk SSD 250GB
CPU: Core i5 4670k
