nForce 2 Northbridge getting scalding hot. Problem?
DaLurker
Just wondering, the northbridge heatsink is getting very very hot in my computer. It's so hot I can barely hold my fingers on the heatsink for more than a few seconds. Will that be a problem? Do I need something like the Thernalright NC-1 with the Delta Fan?
With the heatsink being so hot, you know that the heat is being transferred efficiently from the northbridge chip to the aluminum heatsink. Mine didn't get hot at all, and only started to get hot once I upgraded to a Zalman NB47J northbridge heatsink paired with Arctic Silver Ceramique. If you want the best solution, then the Swiftech MCX159-R is hard to beat, though it doesn't run passively.
I fixed a friend's nf2 NB overheat by reapplying AS3 and changing retail heatsink by a intel celeron 400 one :D
I always knew those heatsinks/fans would help me one day :)
OldMX
OldMX
Hehe.... i look back at those heatsinks now, and I compare them to one of those stock Prescott (saw them at TigerDirect yesteryday... :eek: THEY'RE HUGE!) and go wow.... how'd we ever get by with so little heat.
I'm thinking of using my Zalman backet, get a Zalman Northbridge heatsink and a 92mm fan to blow air over the Northbridge and the caps around the CPU. Damn... I went with watercooling to have less fans... Now i have the same amount of fans as when I had air cooling. Only consolation is I can run them all at 5 or 7 volts :)
Get a heatsink with a fan on it. Or just rig a fan onto the current heatsink. Unless of course there is no heatsink on it :eek:
If the heatsink is getting that hot, then don't remove it. It's doing a great job of transferring heat, so you just need to add a fan to it or make sure it's getting some more airflow.
Remember, they're called heatsinks for a reason. :) A cold heatsink usually means something isn't attached right, or you've got a ton of airflow.
