NF7-S not detecting RAID Drives
Neo_Cloud_99
I recently got my replacement NF7-S... my other one died from an experiment icon_sad.gif ... anyways...
I have RAID enabled in the BIOS. When the RAID BIOS comes up and says press <ctrl + s> or <F4> to enter RAID utility I try both buttons many times but it wont enter the utility. After it sits there for about 30 seconds it will say no devices detected, utility disabled, press any key to continue blah blah blah...
I know the drives work they worked with the old board, I tested them in my old system and they detect fine. I've double checked the SATA connectors and I've used another cable to see if that made any difference. Power connectors are good... I know you cant put any of the cables on backwards... lol..
Did I miss something in the BIOS? Some sort of jumper? I dont remember having to do anything else that I havent already done last time.
This happened to a guy I know, but he was trying to use IDE drives . . . obviously that's not your problem ;)
Dont you need to run the XP CD and hit F6 to install the drivers first?
Just wondering...
You ARE using a PS/2 keyboard, right? I ask only because I had a similar problem using a USB keyboard that, for one reason or another, would accept the "esc" or "F8" or whatever to get into the bios, but not anything after that until in a windows environment.
If that's not the problem, then Summoner probably has a good question/point!
Yeah I have tried a PS/2 keyboard and a USB keyboard. If I dont have anything set up in the RAID BIOS windows wont detect anything anyways. I cant even get in the BIOS.
Plus I already have Windows installed on my 2 RAID drives, they are in a RAID 0+1 configuration. I shouldnt need to reinstall anything, I just need to get the dang drives to recognize :(
So you swapped in the exact same board?
I also have the NF7-S, you sould make sure that you have the latest BIOS version, the latest version is 28.
Does your keyboard work when you get into windows? check to see if your keyboard has office features... turn the "office lock" off then try and get into the BIOS, or the RAID utility
You're all missing the point, his keyboard has nothing to do with it. The controller is not showing the disks when it initializes on bootup. He doesn't need to hit F6, that's when you load the drivers in Windows XP or 2000 to install on a sata/raid controller.
