X NetJag X
- Sep 8, 2000
Well, here it is, my next project. I am getting a Silverstone TJ04 and being black, I dont want to paint it. SO....what's black, fun, and different?
SIMON!
Here's my plan, 4" CCFL's w/ electrical tape to make the light go where I want it, and only where I want it. The back of the case is made for an 80/92/120 mm fan, and I'm planning to get a 120mm radiator w/ fan, so there would be a 120 on the back...with this fan grill:
The fan grill will be black, with LED's built in, shining the light where it needs to go.
Here's the tricky part. I want to have a Simon (the vintage edition, not the new ones) in a holder up on top. You can take it down, and play the game (there would be a wire attached to the case) using the lights from the window. That's where I need the electronics help. I don't know how to hack into the Simon and go from it, to the cold cathodes and say "ON" or "OFF"
I do not currently own a Simon, unfortunately, so I can't open it up and figure it out. I'm going to be buying one on ebay soon (their cheeeeeeeap) so I might just buy 2.
If anyone has any suggestions, comments, or improvements to my idea, don't hesitate to voice them. I will be starting a worklog once I get the case, and start cutting it.
(and for anyone who is curious, yes, I am still working on my Contra case as well.)
SIMON!
