it looks like they won't do anything about it. You have to find out what the particular manufacturers policy is on dead pixels and take it up with them.
You can probably just return it, although I don't think you'll get it all back (restocking fees and all that) unless it's actually defective.
They'll tell you to contact the manufacturer about it. Since all manufacturers have different opinions on how many dead pixels are acceptable, newegg doesn't get involved. If you want to return it (because of the dead pixels or otherwise) they'll more than likely charge you a restocking fee
Correct. If you're a longtime customer or something, they might be willing to cut you some slack, but AFAIK, they won't touch it. I believe that most stores (retail or electronic) have a similar policy. They probably don't want to get stuck with a monitor that the manufacturer won't take back
HP's policy was amazing. I bought my ZR24W from Cost Central, and it had a dead pixel. I called HP's business customer service (it's a pro level monitor), and within 5 minutes they had scheduled a site visit for replacement.
Someone showed up the next day with a brand new panel, hooked it up, tested it, and left, 15 minute job.
I think newegg's monitor return/replacement policy was changed i believe, i asked newegg with chat two days ago and they said as long as you are replacing it they won't charge you restocking fee. although you might just wann contact them and make sure of it.
here you can find the detail standard return policy. i might be wrong but one of the reason i didn't bought the Asus new 27inch LED display i will wait till it hits costco/sam's club/amezon
