I am looking to try water cooling, I know nothing about it, even though I read some threads here, I am going to need it to cool the E6600 with the evga 680i nvidia board, any suggestions on the most reliable and easy set up kit that I can buy? also I do move my system around some times to either add or remove components, I upgrade quite often, is this going to be a problem with water cooling? how often do I need to add water? thank you in advance, I have the Antec TX TX1050B Black Steel ATX Mid Tower, any suggestions or advice would be appreciate it.
