Newb Question on Temps when OCing E6600
I'm a semi-newb when it comes to the level of OCing that I've undertaken with my new build. And I've been, what I believe, is rather successful. In fact, more successful than probably any of the numerous reviews/comments on OCing the Core 2 Duos on a 680i that I've read. Which has led me to question what the people writing the reviews consider "stable" as opposed to my experiences.
I've gotten my E6600 on an eVGA 680i with 2GB of Corsair DDR2-800 up to 4GHz (actually 3.96Ghz to be specific) with a bump to a 1799MHz FSB. This is with standard air cooling and just a Zalman 92mm on the CPU. I've also OC'd the 8800GTS to 650/850 from 513/792. 3DMark06 scores went from 7721 to 10862 -- not bad if I may say so myself.
My question is whether the temps that I'm experiencing (outlined below) are something to be overly concerned with, and, if so, what would be the easiest way to lower them without sacrificing too much of the OC speed.
At idle in BIOS, the CPU temp is ~41C. Not bad. When in Windows this jumps and holds at ~51C. When running Orthos it will quickly jump to ~70C then slowly climb to ~75C where it will hold for hours (I've tested up to 6 hours with no problems).
I was a little concerned with the 75C. So I ran decided to run a "real world" test and ran tests using Company of Heroes, the most "real world" resource intensive thing I could think of. And there the temps never go over 62C. Something, in my mind, hardly to be concerned with if that's the highest that I can expect temps to reach in real world usage.
And throughout it all I've never had any stability problems at all. I had some graphical artifacts when playing Act of War, but I think that was a driver problem rather than a system problem (since that game is decidedly less resource intensive than CoH).
Are my temps anything to be genuinely concerned with? I appreciate the feedback as I'm new to this level of overclocking.
well 70+ is too high, but under 65'c is fine for normal world conditions...
Get that 8800GTS Vram to 1000mhz!
zalmans seem to suck for intel c2d rigs, my 9500,9700 both suck ballz. Luckily my brother was willing to buy me a Tunitower 120mm. I just hope it fits!!!
As an update, I guess the thing has decided to break in quite a bit more since yesterday afternoon.
My idle temp within Windows has dropped 10C to 41C. Now full-load (which I never come close to within a game) only takes me to about 65C.
Doesn't seem too bad for 4GHz on an E6600, but then I'm no expert.
Holy crap, I've just orderd a E6600, do they really get to 4Ghz? Getting it to 3Ghz and matching the E6800 seemed impressive.
I'm going to just overclock with the stock cooler, I doubt much past 3Ghz is going to do my rig much good :)
