Here's the setup for my new system:
ASUS K8v SE Deluxe
AMD Athlon64 3200
Crucial DDR-400 512mb RAM times two for 1024 total
ATI Radeon 9800 Pro
Western Digital 120GB SATA hd
I think thats about all the perks..
My problem is that when I'm using the computer, it just restarts after some time. It varies depending on what I'm doing. If I leave it idling in Windows, it runs fine. But as soon as I kick up BF Vietnam, FarCry, or try to install something, it just restarts. It's like whenever I put the system under a somewhat heavy load, it restarts. I've been combing through it for days now, and I thought it had might been a problem with something overheating, but for all I know, I'm way off.
At first I though it might have been the videocard, so I swap it out with an older Nvidia card I had. Same problem. Then I thought maybe the cpu is overheating, so I check the heatsink and reapply some thermal grease, yet it still restarts under a load. Odd thing, though, is that it seems to extend the time before it restarts if I lay it on its side, which makes me think the heatsink and CPU aren't contacting properly.
I keep toying with it, but to no avail. It's driving me insane that I can barely use this system that I was so excited about. Right now I'm on another computer downloading the newest via 4 in 1 drivers and the AMD Athlon64 drivers for XP. But in the mean time before I get a chance to try them, does anyone else have ANY ideas whatsoever? Try a diff heatsink/fan, any drivers I may be missing, motherboard possibly grounding itself out?
Any help is greatly appreciated. Thanks, Matt
BTW, CPU temps seem to be around 108/109*F, MB temp around 90something if I remember right, and case temp ~80-85*.
ASUS K8v SE Deluxe
AMD Athlon64 3200
ATI Radeon 9800 Pro
