new system final specs
AMD_Gamer
does anything look wrong with the specs for this awsome new system im building? the only thing im still not 100% sure about is weather or not the memory is what i should get? and other suggestions
i can order everything from newegg and totoal price comes to $1,941
AMD Athlon 64 3500+
MSI "K8N Neo4 Platinum SLI"
OCZ Gold Edition Rev2 Dual Channel Kit 184-Pin 1GB(512MBx2) DDR PC-4000
eVGA nVIDIA GeForce 6800 GT Video Card, 256MB GDDR3 ( PCI EXPRESS)
Creative Labs Sound Blaster Audigy2 ZS GAMER Limited Edition PCI Sound Card
Lite-On 16X DVD Dual Drive, Model SOHW-1633S Beige, Retail
Thermaltake Venus 12 CPU Cooler For AMD Opteron and Athlon 64
Western Digital Raptor 74GB 10,000RPM SATA Hard Drive
Western Digital 300GB 7200RPM IDE Hard Drive, MODEL WD3000JB
ENERMAX Noisetaker 600W Power Supply, ATX 12V V2.0 compatible, Model "EG701AX-VE SFMA 2.0 SLI"
I'd check the motherboard for compatibility issues, you can call the mfg and ask. (for the ram)
~Adam
There have been a lot of threads recently in many forums about the fact that with the current AMD systems, dual channel or not, there isn't much benefit to getting the really fast/expensive ram.
and it costs about twice as much as standard pc3200 with little gain in speed and likely a loss in stability
well it might not even work with your motherboard. i've heard of people having problems with certian brands and cas latecnies with motherboards that will take another similar ram. the weirder your timings on ram are, the greater chance for data corruption too.
Kingston or Corsair would most likely be compatible, like I said call the mfg and get a list of ram that's guarenteed to work with the mobo.
~Adma
