New RAM Installed... RAM Problems or Other Problems?
zacdl
I'll try to keep this as sort as I can, so bear with me.
I bought 1GB of RAM for my notebook (PC2700), the auction had said it was only used a week.
I disassembled the notebook to replace it on-board (rather than the easy to access door, in case I want to upgrade that stick later- it will be easier).
I booted it up, programs loaded quicker, used it about 5 minutes, and got a BSOD of some sort (No readable words- scrambled jibberish- looked like a display problem, the words were all smeared).
Upon trying to boot, I would get to the Windows Loading screen, I would see a flash of blue, and it would reboot. It did this every time.
So, I ran Memtest. Left it running about 6 hours- left the house.
When I come back, I notice Memtest runs about 10 different tests, but the first one completed (see pics).
Anyway, I figured one test was good enough. Tried to boot the machine again- and it works. I have written this whole post so far and it has not died again on me.
My questions for you- is this RAM bad? Even if it partially works (it can at least START loading Windows, and it did work those 5 minutes, and right now). It partially working means it cannot be all bad can it? Could it be bad seating (Short on time right now to check, but I am sure I seated it firmly)?
What would cause this?
What do these Memtest results tell you?
At any rate- I'll leave it running tonight and see if it crashes on me during the night.
Thanks for taking the time to read!
Edit- it happened again. Its like after a certain period of activity- it crashes. I would say it may be a heat issue, but like I said- I ran Memtest just fine for 6 hours. I did manage to get a shot of that messed up BSOD:
Edit2- Computer froze completely up as well the second time around.
Edit3- Third time around, been running for 25 minutes now with no problems. Going to bed- hoping for the best tomorrow!
Here are pics of Memtest:
I would definatley say that the RAM is bad or has a compatibility issue with teh lappy. Put the old RAM back in and/or buy some new sticks, not used sticks.
After booting up 5 times, and all 5 times having troubles, I put my old RAM back in. Left it overnight- it works fine.
The guy I bought it from emailed me, said his dad works at Microsoft (I guess for some reason that makes HIM quailified in PC stuff). He said I should install the OS with that RAM in it.
Well... the OS doesn't use any sort of drivers for RAM... plus the Memtest failed.
