Kckazdude
- Jan 4, 2002
Would love to hear some thoughts negative and positive on it. This is a Cheiftec Dragon steele case that I am starting out with. Heavy and ugly are the first thoughts that came to mind. I dont really have any set ideas in my head as they are just coming to me as I get there. The theme I have decided to go with is a Harley-Davidson type case. Hopefully when completed it gives an impression of a modded H-D. So on with the pics.
Fresh out of the box and creating a hell of an eye sore
First thig to go is the door. Looking at what I have to work with to get rid of the finger holes for the drive rails.
Finger holes, hinges, and latches holes all filled in and bottom center cut out.
Since the finger holes also allowed the rails to slide in and out I had to devise a way to mount the optical drives. Disassembling the rail mounts themselves gave me the soltion. Had to remove and cut holes in the cage mount to allow for mounting.
Now back to work on the front bezel. I knew I wanted something to allow as much airflow as possible and I wanted a window on the bezel.
Next was to make some mounts that would allow me to mount some lights onto the front along the CD drives.
After getting this much completed I decided that the front window/opening has been done a few too many times. Looked a little too used. So a redisign was needed.
Thats it for now. Am working on the side window and getting the window cut and shaped for the front.
