My wife has decided she really wants a digital picture frame. I figured I would get one for xmas comming up, they go in the $100 range for a 8"-ish model.
Then it struck me, I have a semi-broken 17" lcd collecting dust under my bench at work and a plethora of computer parts lying around, so I figured a 17" digital picture frame would be much better, and probably not cost me much more out-of-pocket.
My inspiration is the pictureframe pc featured at mini-itx.com. Ever since I first saw that years ago I've really wanted my own. Now is as good of time as any!
First, the donor LCD. Yes it was taking with my crappy phone cam but I promise better pics in the future. It is a CTL 7GX.
The problem is that the backlight inverter part of the power board is burned out. There is an image, just can't see it.
I plan on using some case light CC inverters to power the lcd tubes (I've done this before) and power them off the pc power supply.
The last couple of weekends I've scoured Goodwills looking for a frame to base this on but no luck. I might have to either make one or have one made.
Here is what I have assembled so far:
MSI KM4AM-L motherboard.
a choice of cpus, but will probably use an athlon xp and underclock it to 100fsb.
ram, probably 256mb
hard drive
200w microatx power supply
spare copy of XP.
Need to get:
wireless connection (usb or pci)
2x dual-light cold-cathode inverters
card reader
some usb ports
some form of wireless or small usb kb/mouse.
and then switches and other stuff, you know normal stuff for case mods.
I have to do this all clandestinly too, with the work done either at work or my friend's shop as it is to be a surprise.
Next step is to aquire an actual frame, or the inverters to test the monitor and install windows.
ram, probably 256mb
hard drive
spare copy of XP.
Need to get:
card reader
some usb ports
