Cerulean
- Jul 27, 2006
Greetings,
We have a brand new Windows 2008 R2 x64 terminal server. Additionally, we have a Windows Server 2003 x86 print server. All prints to the 2003 server are problem-free and print fine. However, because we have upgraded most of the company's computers to 64-bit Windows 7 and moved many users from PCs to the 2008 R2 x64 server, we've been forced due to resource constraints and perhaps to some degree 'bad planning' to use the 2008 R2 x64 server as a print server for x64 machines and users.
Using the latest HP Universal Drivers, when users print to many of the printers at the office (through the 2008 R2 x64 server), they get an extra page with this garbage printed to it [1]:
[1]
(I censored out the actual username there)
This problem would happen for these old HP LaserJet 2200 printers (parallel-based, long before Ethernet connectivity came to be). So, we thought, "it must be cause these printers are so darn old that even though HP says the UPD supports these models, it obviously doesn't! We need to upgrade office printers anyway because none of the printers here support automatic duplex."
So, we got a new printer: HP LaserJet 2055dn (networked, supports auto-duplex)
Low and behold, the problem is not solved by getting a new printer.
We only bought one so that we can diagnose the situation and get it solved before upgrading the entire office's printers. When replacing, we just created a new TCP/IP printer port (for the DHCP-assigned & reserved IP address of the new 2055dn), went into the existing printer queue DIVI_LZ.P06, changed to the TCP/IP printer port we created, went to the Drivers tab, and verified that HP Universal Printer Drivers was selected.
In addition, we have these symptoms as well:
[2]
[3]
We have a lot of HP LaserJet 1100 parallel-based printers, a couple 2200, and a few stray/other model. We're mostly experiencing these problems on 1100 and 2200 printers. On some 1100 printers, we get a Windows test page like this too [4]:
[4]
We were using 5.2.3 UPD PCL5 drivers on both the x86 and x64 servers. I had upgraded the UPD drivers on both servers to latest 5.4.0 -- made no difference whatsoever. I even tried PCL6 on the x64 server, but that didn't work, so I switch back to PCL5 (just wanted to see the difference). I never tried using the PostScript/PS version of the HP Universal Printer Drivers.
And finally, just to clarify: the x86 server has never given any troubles with printing, only the x64. Using default for everything for creating printer queues, no special tweaks, fixes, configuration, etcetera -- just setting up new printer queues like any normal consumer or network administrator would.
[1]
![ExtraPrint_PJL.png](http://www.hlrse.net/Qwerty/ExtraPrint_PJL.png)
- The above extra printout image [1] -- we get this easily if we just print a simple test page
- When printing PDFs or Excel sheets, only blank pages (both sides) come out -- nothing actually printed
- When printing e-mails from Outlook 2010, this [2] and this [3] happens
[2]
![EmailPrint_SemiGarbage0.png](http://www.hlrse.net/Qwerty/EmailPrint_SemiGarbage0.png)
[3]
![EmailPrint_SemiGarbage1.png](http://www.hlrse.net/Qwerty/EmailPrint_SemiGarbage1.png)
[4]
![TestPrint_GarbagedTitle.png](http://www.hlrse.net/Qwerty/TestPrint_GarbagedTitle.png)
