New HD problems need opinions
Gutlass Cutlass
Installed new WD 160gb HD. INstalled a fresh copy of XP pro all was fine for a few days then it stated lockin up and glitching on me. So I installed Xp again and now it wont wont boot past the Xp start screen. Did the HD drive take a shit?? Or is it something i'm doing wrong???
Are you overclocking? That would be the first culprit.
Is your power supply cheap? That would be the second.
*Then* look at the hard drive.
i just installed windows i was only loading apps back on. ANd this power supply use to supply 2 hard drive and now only is running. Plus it was working fine for 3 days
have you tested the memory?
have you run the HDD manufacturer's diagnostic?
