I'll try and keep this as short as possible. Last Saturday my 120gig Maxtor HD failed to boot so I ordered a 160gig Hitachi one from Newegg. It got here Thursday and the install went great. I left it disconnected from the net while I installed Norton and my drivers. Then I did a virus scan and ran Windows Update. After that I connect my 120gig Maxtor as a Slave so I can get my MP3/Favorites/Pics and some school work off it. It gets past the post all the way to the XP loading screen and everthing seems to work fine...... untill I see the post screen again. It seems the computer rebooted its self. I boot from the Ultimate Boot CD and it sees the 120gig drive and both its partitions from FDISK. MaxDrive gave me and error code of Y42S57, no clue what that means but it offered to try and fix the problem at the risk of loosing data, so I passed. Now my question is is there anything I can do to recover the data from the drive? I've tried messing with jumpers, putting them on seperate IDE channels, and messing with the bios. Only other things I can think of are Fdisk /mbr or the Savepart program on the UBC. Are there any other things I'm overlooking?
Specs incase it helps:
p4pe
2.66b
512mb RAM
Antec True 430
Win XP Pro w/ Updates
p4pe
2.66b
512mb RAM
Antec True 430
