New fan(s): CPU and System
mash
Hey, I want to replace my stock fans with better ones. My specs are in my sig. I want to most powerful fan to be for my CPU, which runs at 45-50 @ stock. I was thinking about getting one of these for it. I have 3 case fans: a 120mm LED, a normal 120mm, and a 90mm on the side panel. I'd like to replace all 3. Noise is more important for these. I would one of the 120mm fans to still be an LED fan. Should I go for another panaflo for the remaining 120mm? Any suggestions would be appreciated.
endpcnoise.com sells Antec Tri-Cool fans that they have pulled from P180 cases. They are really cheap and not bad for the price. I bought a few of the 120x38mm (thick) ones to replace the thin units that came with my P180. Set them on low and feel the flow...
