weemanbran
- Dec 6, 2007
Ok, so I just purchased a Q6600, 4gb g. skill ddr2 pc6400 ram, and a DFI lanparty p35 mobo. I haven't ever build an entire PC before, just installed a video card, ram, and PS.
Mobo: http://www.newegg.com/Product/Product.aspx?Item=N82E16813136043
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
So I just get this all today and I installed the CPU, ram, and Mobo correctly to my knowledge. Powered up the PC and it showed the DFI lanparty logo then went to the black screen where it shows specs of the PC etc. I have never installed a Mobo before, but just from random reading etc I thought I needed to reset the CMOS. Read the manual, I guess it is supposed to restore to default settings not really sure if it was needed because it didn't change anything in the bootup. Anyways it is not bootting into Windows and this what I am seeing in the black screen of specs etc.
Main Processor: Intel(R) 2.39 GHz (266x9.0)
Memory Testing: 4193280k Ok
CPU Brand Name: Intel(R) Core(TM) 2 Quad CPU Q6600 @ 2.40 GHz
CIE BIOS Supported
Memory Frequency for DDr2 800 (Single Channel Mode)
IDE Channel 0 Master: None
IDE Channel 0 Slave: None
IDE Channel 1 Master: None
IDE Channel 1 Slave: None
IDE Channel 2 Master: None
IDE Channel 3 Slave: None
IDE Channel 4 Master: HDS728080Plat20 PF20A21B
IDE Channel 4 Slave: None
CMOS checksum error - Defaults Loaded
Warning! CPU has been changed
Please re-enter CPU settings in CMOS setup remember to save when you are finished
Press F1 to continue, DEL to enter SETUP
12/24/2007 - Bearlake - 6A790d4WC-00
Any help would be appreciated!!!
CIE BIOS Supported
