New Computer help?
This is the gaming pc im planning to buy in the 15th. Do u guys see any issues of compactability ? any suggestions??
CPU: Amd Athlon 65 3500 http://www.newegg.com/app/ViewProductDesc.asp?description=19-103-463&depa=1
Mobo: K8n Neo 2 Platinium http://www.newegg.com/app/ViewProductDesc.asp?description=13-130-468&depa=1
Case: PlusView1000AMG ( antec)
http://www.newegg.com/app/ViewProductDesc.asp?description=11-129-124&depa=1
RAM: Kingston HyperX (Dual Pack) 184 Pin 1GB(512MBx2) DDR PC-3200
http://www.newegg.com/app/ViewProductDesc.asp?description=20-144-114&depa=1
PSU: http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-908&depa=0
HDD: http://www.newegg.com/app/viewProductDesc.asp?description=22-148-030&depa=1
Gfx card: Gforce 6800 gt http://www.newegg.com/app/viewProductDesc.asp?description=14-133-116&depa=1
DVD burner: http://www.newegg.com/app/ViewProductDesc.asp?description=27-152-031&depa=1
Flopy drive:http://www.newegg.com/app/ViewProductDesc.asp?description=21-103-203&depa=0
Optical drive: http://www.newegg.com/app/ViewProductDesc.asp?description=27-151-208&depa=0
Sound Card: http://www.newegg.com/app/ViewProductDesc.asp?description=29-102-171&depa=0
Fan: (this is xtra cuz case comes with 2 alrdy ) http://www.newegg.com/app/ViewProductDesc.asp?description=35-129-007&depa=0
So what do u guys think? This good system for U$ 1500?Any suggestions? My friend told me this psu wont run my comp because it doesnt have 24 amps on the 12 rail or something o_O is this true? Do i need to buy an alternative cpu cooling? If i do which do u recomend? Can any one tell me in retarded newbish talk how to install windows on a SATA HD ? im such a newb -_-. Any help here would be very much apreciated
Thanks
lol saved u eh? i deceded so switch from newcastle to the cpu u told me to so u saved me too lol >_< we r even. I rather get the Retail version because i Cant never ever ever fill up a 200 gb hd and i trust retail more so yah >_<. Do u see anything else that i chould change or get??
u cool meh thanks for replying :D
I just bought an Antec Truepower 430W a couple of weeks ago and it has 26A on the 12V rail. Antec's website also collaborates this statement: http://www.antec.com/specs/true430_spe.html
It's obvious that the PSU model has underwent a revision by Antec and Newegg is yet to update the specifications.
Anyways, yes, the Antec True430 is a very stable and solid PSU (not to mention quiet) and I haven't noticed an increase in my case temp that some ppl complain about due to the slower fan speeds. Given my experience, I would recomend it to anybody (but take into account that I'm not exactly running a very power hungry system).
thanks a lot man i wasin doubt there, my pc isnt going to be too hungryas well so i think this will do. Any other issues u guys (and girls?) see here?
thanks
How hardcore are you about sound? I got a Turtle Beach Santa Cruz from buy.com for $36 shipped. This card sounds great to me (never tried an audiology) and I don't think I could be happier.
And I got my 1GB Kingston HyperX 3700 for $225. Have you looked anywhere else for prices? You should check out zipzoomfly, or if you're more bold (like me) pricegrabber.com. You've got to have standards and a plan to use pricegrabber.com, but it saved me at least $100 maybe more.
I'd probably go with a different manufacturer for the 6800GT. PNY isn't the best around, and there's no bundle. Personally I'd be tempted to give the LeadTek a try if I had room for it based on that massive copper cooler. Some of the others also have some bundled games. EVGA includes Doom 3 for example.
which nvidia gforce 6800 gt are there and which one is the best? also isnt the audio i got the best one out there for gaming?? thanks a lot for replying guys
I'm not too much into audio, so it very well might be the best for gameing. But I don't need THE best, so I can just settle for better than I had before. And the santa cruz and Logitech Z-3 speakers are definately better than I had before.
