New Case With Cheap Cooling
SilentScope
I am getting a new, cheap case for a relatively cheap computer:
http://www.newegg.com/Product/Product.asp?Item=N82E16811164071
As far as I can tell, it comes with no cooling. I was thinking of using the following configuration:
I would use this card to bring in air (since there is only 1 fan opening on the case, and I don't feel like doing a custom job)
http://www.newegg.com/Product/Product.asp?Item=N82E16835150006
And then this fan to shoot out the air:
http://www.newegg.com/Product/Product.asp?Item=N82E16811999966
Will this be adequate for a 3 GHZ Pentium 4 (It already has a mighty fine Artic Cooling Heatsink/Fan), with a X1600 PRO, and 1 GB of 3200 RAM?
I'm not interested in spending any more money, I just want to know if it works. Thanks for the advice anyways.
or an antec 3000b for 50 bucks. don't buy fans from newegg it's a waste. look elsewhere. i bought a bunch from www.svc.com. good shipping deals there.
Yea you are better off buying a $50 decent case. Whats the point of buying a shitty case then wasting money on shitty coolers that are going to be around $50 at the end anyway.
my pt exactly
