New Case Fans/ HSF
KINgGh0sT
Looking for new Case Fans and a new HSF...
Looking at..
For My Case...
4x Panaflo 80mm 'LOW' 24.cfm 21dba L1A Fan
For my HS...
I can't decide between..
Panaflo 92mm "HIGH" 56.8cfm 35dba H1A Fan
OR...
Panaflo 92mm 'MEDIUM' 48cfm 30dba M1A Case Fan
Strapped to a SP-97
"Panaflo 92mm "HIGH" 56.8cfm 35dba H1A Fan"
Go with that one and put a fan controler on it, turn up and down as necessary.
I've got the 92mm M on an SP-94 and I like it because I can't hear it. If you've got good case airflow this will work great for you.
I need to get 3 80mm L fans for my exhaust though, the Antec fans only push a whopping 17cfm. Once I get better exhaust and my airflow improves, I bet the 92mm M on my CPU will be even more effective. Right now my hot air isn't leaving as quickly as it should.
