Hi all - After reviewing my specs (core 2 duo 6700, 4gb ram, dual sli 7600gs, 600watt ps, ASUS Pn5-sli se mobo) and the case I have it in (some POS midtower from the computer show with the worst card management system I've ever encountered around the back) I decided that I had too much in too small of a space, and I'd be better off with a full size tower. So, after deliberation, I got the AeroCool ZeroDegree SV case from NewEgg.
The thing about this case that completely won me (as you'll see if you look at the specs) is it's been designed completely upside down. This sets the motherboard on the left side wall, with the seven PCI expansion slots at the top where they're easier to get to. The access panel is on the right and has a huge fan (250 mm or something) The psu is also on the bottom, which keeps the whole thing much more stable and not so top heavy - why has no one done this before?
Anyway to get to the advice part - does anyone have any experience with a reversed case like this, and any recommendations as to cable management to get the best possible airflow? My PSU has a lot of extraneous cabling that doesn't get used and the midtower has presented lots of issues. I suspect they may go away with the new design with the psu on the bottom, and the extraneous cables can get tucked away under the tray or something. But what do youall think?
~D
~D
