I just had a new build for my parents with amd x2 cpu, ecs a780gm-a mobo.
I have installed windows xp 64, Comodo firewall/AV, drivers for everything (ATI, sound, etc).
Now, everything boots up fine and it logs in, but after this, the desktop icons does not show up, and right-clicking the desktop doesn't work. However, the ATI catalyst, wireless network, and the Comodo firewall icon loads in whatever the area is called next to the clock, and the Start button works. When I go to my computer through the start menu, it hangs for a little bit, then the windows open.
After maybe couple minutes, then the desktop icons load and the rest of the other icons in the bottom right area loads.
Now, I have googled this issue, and explorer.exe is running when this happen (start menu works, so its not the explorer.exe problem).
Any ideas?
Thanks
Any ideas?
Thanks
