master noran
- Dec 10, 2006
Ok so the story is I put together this PC. Everything except a GPU, I'm going to get that next week from a guy I know.
e7400
GA p43 ds3l
500gb sata HD
dvd writer
4 gigs mushkin ram, 800mhz
enermax 535 watt psu
scythe mugen cooler and a lian li a05b
Ok, put everything together and left it on a typical kitchen table size table. My brother kicked it off. Heatsink flew of the MB from the impact, no cracks or breaks on the MB. The only things that look damaged are the HS and the case. I plug it all in and get post sounds for a GPU and or display problem (because I don't have a gpu in it) is there a chance when I plug the GPU in next week it'll be messed up?
e7400
GA p43 ds3l
500gb sata HD
dvd writer
