Alright after P4 and a crappy Dell I built my first pc.
Case: Antec 900
PSU: Sunbeam 580WAT
CPU: Intel E2180 2.0GHz (will overclock this)
MOBO: ECS 610i/7050
RAM: 2x 2GB Corsair DDR2-800 RAM
GPU: 8600GTS 256MB XXX
Hardrive: Western Digital 320GB 7200RPM, and Western Digital 80GB 7200RPM
Alright so I am going to be using this rig for gaming, and homework
, and random, stuff like music, movies, burning crap.
My question is my motherboard says it supports DDR2-800 over clocked, and the guy I bought it from said he runs DDR2-800 in the same motherboard.
So why does the manual say it has to be overclocked to run?? On the offical website it says it supports DDR2-667.
Anyways 99.9999999% sure it will work.
The CPU and motherboard were really cheap.
In December planning on getting a Intel Q6660, and a 680i.
The motherboard specs http:
//www.shopwiki.com/detail/?q=7050%2F610I+mATX+Motherboard&s=387815&o=224789424&d=ECS+GF7050VT-M(V1.0)+Core+2+Quad/+Geforce+7050/+DDR2/+A%26V%26L/+MATX+Motherboard
My ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184
So will it work
I will also post pics when I finish bulding it, should be tomorrow!
Also the heatsink that came with my CPU had Thermal Compund applied on it since it was OEM, so should I add more?
Case: Antec 900
PSU: Sunbeam 580WAT
MOBO: ECS 610i/7050
My ram
So will it work
