Hi,
Having problems with my newly-assembled computer. When I turn on the power switch the fans just start to turn and then stop. Motherboard lights stay lit. But no other activity. If I push the power switch again nothing at all happens. If I unplug the power supply and then try again the fans will start to spin up. I also noticed after opening up the case and trying to turn on the power that there was also a bright flash of light that looked like it was coming from ICH1OR chipset.
Have checked all power connections many times. Everything appears to be hooked up properly.
At this point only have 1 sata hard drive and one sata dvd drive and the video card installed on system. Also, did try reseating the memory with no change in acitivity.
System specs:
Asus P6T Deluxe
Corsair 8 gig memory
Asus ENGTX280 PCIE video card
Corsair HX 1000W PSU
Cooler Master HAF Case
This is the first system Ive built in over 5 years, so I got the pre-built and tested motherboard bundle with processor from Mwave. Put the rest of it together myself. Did I short-circuit something?
Am on my way to work now, so wont be back online for at least 8 hours.
Hal
System specs:
Asus P6T Deluxe
Hal
