Hey all, I'm interested in learning how others have tackled this problem. I have a building where I want to be able to go to either side of the connection and know exactly where the other is. I can do this from the port to the punchdown ( label the port ), but I'd like to be able to do the opposite as well ( punchdown to port ).
A punchdown legend is one method. I was also thinking of setting up a grid and naming the ports associated with the grid as well. What I'm after is something easy to maintain, doesn't require a lot of maintenance and easy to understand. Initial setup isn't so big a concern, as long as I get everything else.
So, ideas?
EDIT: One thing i should mention is that I can't rely on things like computer name, position name or even the walls themselves to stay consistent, hence the grid idea.
So, ideas?
