hey all, I am in the middle of putting a WHS together. on top of that, I have 3 primary zones in the house.
Zone 1 would be my main desktop and the WHS and FIOS modem. it is located in the basement, and currently uses the FIOS modem for DHCP for the entire house. then I have a linksys wrt-610n as the first device after the modem ( the wrt 610n acts only as a switch / wifi router.)
Zone 2 would be my entertainment center, it has a HTPC, PS3, and XBOX360. it is located in the family room. it connects via wifi only right now.
Zone 3 is the shared computer, it is upstairs on 2nd floor. it is a used for basic internet only. it is connected using a powerline network on a dd-wrt router ( cant remember name but it works ok, not great, but fine for now.)
Right now I have Zone 1 connected to Zone 3 via powerline network, and Zone 2 is connected to Zone 1 via wireless. and Zone 1 and 3 provide wifi coverage for the entire house.
my first plan is to move the wrt-610n from Zone 1 to Zone 2, then connect Zone 2 to the other 2 Zones with one more powerline adaptor.
then I need to get a new router ( does not have to be wifi ) to Zone 1, at this point I will run the FIOS modem as a bridge and use the Router to control entire network, it will need to be decent speed and support vpn and Dynamic DNS, but I don't want to spend more then 100$ for this router.
lastly in a month or so I will put a firewall in place.
end result should be, Zone 2 and 3 provide wifi for the house, and both connect to Zone 1 by the powerline network.
then in zone one it will be -> internet -> modem -> (firewall later down the road ) -> "new router" -> WHS, Main computer, and powerline.
(router will connect to internet, modem will be set to do nothing but be a modem, all wifi and router options will be disabled.)
so. will this setup work ? what would be a good router to put in zone one, it will need a large nat table, and a good back-plane w/ gigabit support, VPN, and Dynamic DNS, but not be over 100$ ( fyi if I used incorrect terminology please forgive me, I am no good with that stuff, but I am decent at working on all of it.)
