Neo4 Platinum: 12v Connection Needed?
Bluemagic
So I just got my order from Monarch (wouldn't recommend ordering from them, long story) and as I hooked up the 400w Sparkle PSU I have (about 3 1/2 yrs old) I noticed there's a connection for a 12V 4 'prong' cable, which my PSU doesn't have. Do I need to buy a new PSU now?
Bluemagic said:
Is there reason to believe using one of these isn't safe? Is the molex connector not putting out enough juice?
In my opinion, yes to your second question. Your power supply may be 400 watts, but older high-wattage PSU's often didn't have a very high amperage on the 12v rail, leading to instability on today's systems which use the 12v rail for CPU power. My 3-year old Enermax 430w only had 16A on the 12v rail; it was top of the line when I bought it, but when I went to a Barton-core Athlon XP, I had stability problems. I cured them by going to a dual-12v rail Enermax 470w that had one 12v rail for the mainboard/cards, and one for the drives. My power supply also did not have the 4-pin 12v connector that my new one does. I would upgrade your power supply if you want to ensure stability.
Not flaming you, but mind if I ask why you didn't like Monarch? Only thing I don't like about them is they ship everything signature required, even my siggy waiver with Fed-Ex doesn't apply, so since I live alone I usually miss a package from Monarch, I end up having to go right before my local Fed-Ex garage closes to get my stuff if I order from them.
Other then that, they have been decent with me. Usually not the cheapest price, but I've seen them cheaper then Newegg, ZZF, GameVE and the rest once in a while, so I keep them bookmarked.
Just curious, and if you don't want to say why you didn't like them, that's cool too.
The reason I wasn't impressed was because I ordered a Neo4 Platinum mobo from them on the 22nd of February, and they didn't ship my order until a week later. Found out later after calling it was because that item was not in stock, despite the website saying so. The 3500+ I ordered from them came NIB with two bent pins; hardly Monarch's fault, but it still doesn't help my overall impression of them lol. To take a look view my thread in the AMD section.
