Ok finished my CPU water loop.
Temperatures are at 50-55C which seems a little high. PD @ 2.66 Stock
I am using Asetek Antarctic block, and a Asetek 12v pump. Theres nothing else attached, its a straight loop from pump to block to radiator.
I am using a Hardware Labs 360 GTX, (the really big fat one) x6 fans, Scythes, 90 cfm
Only things of interest I noticed, is there seems to be a little bit of air bubbles inside, and they don't move. I was worried maybe it was flow or something. Also water isn't touching the top of the antarctica block, because of gravity theres a little space thats empty.
