Just received my Cube case and it is slightly different than the modification template I was going to use. As you can see from the pictures, the rear exhaust holes are square rather than circular, which will make it difficult to have a nice result using the typical circular fan grills. One consideration is to just use the aluminum mesh filters for the exhaust... the picture shown is with a 120mm mesh filter since I don't have any 92mm ATM. Thoughts/suggestions?
Template:
My Case:
Template:
My Case:
