- Dec 27, 2004
I'm pricing out parts and I know I'm going with a LGA 1366 i7 920 CPU.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
I'm looking for opinions for a motherboard that will run completely stock, no OC of any kind, and has to be stable.......rock stable.....under those conditions. I've always been partial to ASUS and Gigabyte, not familiar with ASROCK or foxconn or any other brands.
Since I'm not doing anything crazy, stability is the only operative word here. I'm open to idea of other companies if you have had experience directly with them with this CPU.
Can anyone recommend an ATX board that will meet this requirement.
It is being used for a DJ computer system that is the core of the entire system running Serato ITCH, so I can't be anything flaky, it has to be rock stable.
Thanks
Chris
Thanks
Chris
