Need some input
Tim Wardlaw
Hey guys,
looking at building a new system. Can I get some feedback on my selections below? Thanks,
Tim
cpu: Intel Core 2 Quad Q6600 Quad Core Processor LGA775 Kentsfield 2.40GHZ 1066FSB 8MB
video card: EVGA E-GEFORCE 8800GTX KO ACS3 PCI-E 626MHZ 768MB 2.0GHZ GDDR3 Dual DVI-I HDCP HDTV Out Video Card
mobo: EVGA Nforce 680I SLI LGA775 Conroe ATX DDR2 2PCI-E16 2PCI SATA2 RAID Sound GBLAN 1394 Motherboard
ram: OCZ EPP Enhanced Performance Profiles PC2-7200 2GB 2X1GB DDR2-900 CL4-4-3-15 Dual Channel Memory Kit
DVD: NEC AD-7170A DVD+RW 18X8X16 DVD-RW 18X6X16 Dual Layer 8X IDE Black
cpu fan: Zalman CNPS9500 At LGA775 Heatsink Fan 92MM Fan 1300-2650RPM 18-27.5DBA
Hard Drive: Seagate Barracuda 7200.10 500GB SATA2 3GB/S 7200RPM 16MB Cache NCQ
Power: OCZ GameXStream 850W ATX12V 24PIN SLI Ready Active PFC ATX Power Supply 120MM Fans
Sound card: Creative Sound Blaster X-FI FATAL1TY FPS 24BIT Sound Card W/ Front Access Panel & Remote Control
Case: NZXT LEXA ATX Aluminum Case Black 4X5.25 2X3.5 5X3.5INT No PS Temp Display Window & Carrying Strap
Part names with or without links would be more helpful, along with more info. What will you be doing with this system? Will you be gaming? If so, what games will you be playing? What size monitor do you have? and what is your budget?
Hey guys,
Sorry about that.
This system will be a gaming machine and the budget is up to $4000 CDN. I will be looking at getting a new monitor as well so any suggestions would be appreciated.
As far as I know the hardware gets great reviews, I'm more concerned with this particular setup. Will the HSF cause any issues with this mobo setup size wise?
Thanks for your replies
I would swap the 9500 for the CBNPS9700LED or the NT series of coolers, especially since you're going to have the nvidia logo all over the inside of your case (mobo and video card). The 680i from eVGA has clearance for either of the larger Zalman coolers. I am using the CNPS9700LED on my e4300, and have it at 3.2 stable. It's a good cooler for the $. At any rate, I see no other issues with your hardware configuration. With an 8800GTX, you could even push a 1080p display at native resolution. Just pick a price bracket for the screen, and see what you can get. IIRC, you guys in Canada have a tough time getting the Westinghouse LVM-37W3, which is a shame since they fall under $1000 on occassion, and are 37" of 1080 loving...wonderful desktop monitor. Your other options are the Dell 24" and 27" WS displays, for a few hundred less. Hell, you could even go with the Dell 30" 2560x1600 WS display if you wanted, but that may put the pinch on a single GTX configuration.
