Hi,
I'm looking to upgrade my desktop within the coming weeks and at the latest early May. I would like to play Crysis, Far Cry 2, Mass Effect and any other graphically intensive games on relatively high settings (shaders and shadows) without AA at 1400*900.
Price/Performance is most important as I am on a budget and will only use this desktop from May-August (not at college). Resale value is important as I would be inclined to sell the graphics card in early September as I head back to campus, and then buy a new one next spring(2010).
My desktop is on XP and my monitor has a maximum resolution of 1400*900. I will not upgrade either of these, just the CPU & GPU.
My desktop has:
Intel Pentium 4 Dual Core 3.4GHZ (old, slow)
ATI X1950 GT (Sold)
3 GB RAM
Windows XP
From the Current Best Computer You Can Get for $X U.S.
I'm certain the Intel Pentium E5200 Wolfdale 2.5GHz will be the CPU upgrade.
I'm not sure about the GPU... it's down to brand new and less performance vs a used card and a bit more performance.
I'm looking at the: 4830, 4850, 9800 GT, 9800GTX+ and the GTS 250.
Which card should I buy?
My budget is $161 USD ($205CAD) which means I could buy the 2.5ghz wolfdale + 4830/9800 GT brand new, or get a more expensive graphics card (9800GTX+, 4850) on ebay that has been used a bit and pair that with the wolfdale processor instead.
Thoughts? I would like to know your opinion.
Also, would I have any problems getting the Very High/Enthusiast settings for Crysis (only for shaders & shadows) on XP?
My desktop has:
ATI X1950 GT (Sold)
3 GB RAM
Windows XP
