UberPooner
- Jul 21, 2005
Hi, im building a new pc. What im looking at rite now is this:
E6600 processor http://www.newegg.com/product/Product.asp?item=N82E16819115003
8800gtx http://www.newegg.com/Product/Product.asp?item=N82E16814130072
Ok, those are the parts that I know for sure that i want to get. Now i was wondering what motherboard that you would suggest. i was looking at this one but im not to sure about it http://www.newegg.com/Product/Product.asp?Item=N82E16813131045 I dont plan on running sli, but i would like to overclock.
Next i was looking at this power supply, http://www.newegg.com/Product/Product.asp?item=N82E16817139001 Do you think that is good for me or could you suggest something better. I like the Modular Cabling Support that it has.
Also I heard that this was good ram, http://www.newegg.com/Product/Product.asp?item=N82E16820145168 would i be good with that or is there something else that i should get.
I am going to be putting it all in a Thermaltake Tsunami Dream Case.
And thats about it.
And thats about it.
