Hey everyone.
Tomorrow morning I am going to buy a 24" LCD and I need help deciding between these two monitors:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009167&Tpk=H243H
http://www.newegg.com/Product/Product.aspx?Item=N82E16824116401&Tpk=VX2433wm
They are both the same price. They seem quite similar except for a few things..
-The newegg link says the Viewsonic has RGB input. I can't see it in the pictures. If it really does have the input connectors that will be a HUGE plus.
-The Acer has 40000:1 dynamic contrast ratio compared to the Viewsonic's 20000:1. Is this significant enough to make a difference? I have never used a monitor with dynamic contrast ratio.
-The viewing angle on the Viewsonic is better.
-The Acer is .4" bigger.
-The Viewsonic is somehow 5.5 pounds lighter?
-I read that the Viewsonic supports HDCP on HDMI while the Acer supports HDCP on DVI. Does this even matter if I dont watch bluerays?
I would really REALLY appreciate any advice on this. I am leaning toward the Viewsonic cuz I loved my Viewsonic CRT. If anyone knows whether or not the Viewsonic does actually have RGB input that would probably be the biggest deal maker. Also any advice on the dynamic contrast ratio would be great.
I was hoping to leave tomorrow morning at the crack of dawn. Thanks much!!! :-D
