mainly gaming
800-1000 cheaper the better
3) Where do you live?
Elgin, IL
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Case, CPU, MB, RAM, HD, PSU, Optical drive, Videocard (everything except monitor, keyboard and mouse)
monitor, keyboard, mouse lol
6) Will you be overclocking?
No
not sure... its a 20" or 22" LCD (building for a family friend or trying to steer him away from dell)
asap
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Basic stuff, firewire maybe, looking at single GPU solutions
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
No, but getting Win7 Home Premium x64
Ok, a family friend is looking to buy a new computer for his kids because theirs recently died. he sent me a link to a dell he made asking for some feedback and I want to try to get him to let me build one for them... The dell was priced at $879 (E7500, 6gigs ram, GTS 240, pretty mediocre imo)
Anyways, at first i was looking at an i5 setup, but then thought why not check out AMD. Only problem is i know nothing about AMD so thats where you guys come in. below are the two setups i had in mind.
---i5---
MB - $160 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131620
CPU - $185 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115220
RAM - $105 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
HD - $100 - http://www.ewiz.com/detail.php?name...-WD1001FALS-1TB-SATA2-7200rpm-32MB-Hard-Drive
GPU - $155 - http://www.amazon.com/Visiontek-Rad...1?ie=UTF8&s=electronics&qid=1266109066&sr=1-1
PSU - $85 after rebate - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
Window 7 - $105
Total - $895
---AMD---
MB - $100 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131398
CPU - $180 - http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Window 7 - $105
Total - $830
these still need a case and optical as well. Am i better off just getting a cheaper Intel MB and going with that? im iffy on the videocard too. should i got 5770? 5850? i want to keep the price close to the dell though. can get a smaller HD too.
mainly gaming
Elgin, IL
No
asap
---i5---
Window 7 - $105
Total - $895
---AMD---
Window 7 - $105
Total - $830
