Need Radiator Suggestions
Ingonuts13
So I am cooling a 3500 AMD64 (90nm) and a 6800Ultra.
Question is, what radiator should I go for? My loop will be 1/2" ID and will have MC6002 and MC50 blocks.
Thermochill 2.120?
or
Thermochill 3.120? (Overkill?)
Any advice is greatly appreciated.
I thought the Thermochills were better than a heatercore?
Also, what about the triple 120mm set-up?( Not necessary?)
Personally, I'm going with the Black Ice Pro 3 w/3 low flow/CFM fans. That's the most rad I can fit in my box.
Only problem is that I can't seem to find Shrouds or Grills for the 3x120mm set-ups.
Actually from what I've seen a single heater core matches a Black Ice Xtreme II, no idea about the Thermochills though, but I would take it a double heater core one with 2 120mm fans on it will outperform it.
Well I am looking for a good balance between ease of installation, clean look, and performance. I thought the thermochills would fit that mold nicely.
