Need Quick Help
Cheetoz
Well, after getting clicks on my IBM Deathstar for about a week, i ordered a new HDD. But today i right clicked on a file, and tehen my computer randomly rebooted, and then the HDD wasn't found. I was sure it was dead, but i just kept restarting my computer hoping it will work once again. It booted into windows, then crashed again. Then i tried again, and it finally loaded windows, very very slowly i might add. Well, my hdd should be comming from newegg hopefully tomorrow, unless hurricane frances delays it. So my question is, should I just leave my computer on till the hdd arrives, or would turning off my computer risk the chance of the hdd not turning on again?
uhh, if it is your main drive, I would recommend turning it off, personally. Rotating whilst things are dying and possibly flying around in there is bad. However, I think you're basically f*cked either way :(
DAMN YOU DEATHSTAR!
