i chipped and killed my first cpu ever. after over 100 installs of amd procs. i killed mine putting on an si-97 heatsink.
so i decided instead of just buying a new socket a proc to upgrade to one of the new 90nm socket 939 athlon 64 chips.
i went with the new MSI RS480M2-IL. got it for 100 bucks. it has everything i wanted. lan, sata, raid, matx, pci-e, firewire, usb 2.0, and most of all: a digital SPDIF coax output
granted the on board audio chip isnt the greatest, and i'll prolly replace it with an audigy 2 zs card later, but for now its good cause i use the same connection for my current asus A7n8x-del board with soundstorm.
grabbed a retail 3200+ a64 chip.
and got the new thermalright xp-120 heatsink for it and a papst 120mm low speed fan to put on it.
i'll juse use the on-board video untill i get a vid card for it. but this is my delima now.
i was checking out some benchmarks on video cards. and the upcomming x800 XL seems to be a good combo of performance/price. its comparable to a 6800gt, but sug. retail for 300, which means i' should be able to get it under 300 shipped once it comes out. but its not out for at least another month
or do i just drop 200 bucks right now for a 6600gt. performance would be less, but id save about 100 bucks. and id be able to get it right now.
i sorta want to wait. but idunno. i figured id ask to see what you guys thought. i dont play religiously, but i do like to be able to from time to time. currently i'm stuck on World of Warcraft which works my current radeon 9800 pro pretty hard. i dont wanna upgrade my vid card to somthing just marginally better ya know?
so what do you guys think? ride out the integrated graphics for a month and get an x800 XL or drop the 200 bucks now for a 6600gt?
EDIT/PS:
anyone need a slightly used SI-97 heatsink? its only been installed twice, and never actually used on the processory since it was dead by that time
i still have the packaging it came in and all the included accessories. got it from newegg for like 50bucks
EDIT/PS:
