Need PC Build Advice
JLove
Hello-
Newbie here...so take it easy on me...;)
I have decided to build a new system around the Intel (Core 2 Duo Quad) Q6600.
The PC will be primarly used for HD video editing and some next generation games like Crysis etc...I would be willing to skimp on the gaming since I have the Xbox 360 to keep the cost down if necessary.
The parts that I need recommendations for are:
Motherboard (I want the latest and greatest for speed (light overclocking) but do not need all the other bells and whistles onboard). I just want the board to fully utilize the features and speed of the Q6600.
Memory (I will use Windows XP 32bit) Should I stay at 2gb or go to 4gb?
Video Card (Should I just get a GTS 8800?)
Power supply (I have a 500w Mad Dog power supply...should I get a new one?
Windows (Should I upgrade to Vista? 32bit, 64bit??? Are there any performance advantages of upgrading windows with this new hardware?)
I am attempting to keep the budget below $1,200 if possible.
Thanks for any assistance.
JLove:D
Gigabyte DS3
2gb of RAM because you are using a 32bit OS.
Yeh, I would get either the 8800gts 640 or 8800gtx.
Also looking to upgrade that PSU might be a good idea.
What size monitor do you have?
If you don't need RAID, then go with the GA-P35-DS3L or the Abit IP35-E. If you want RAID, then go with the GA-P35-DS3R. Other higher end suggestions would be the P5K-E and the IP35 Pro, but I doubt you'll need those, since you asked for no bells and whistles.
If you plan on upgrading to Vista any time soon, go with 4GB and live with the fact that you can't use it all until you upgrade to Vista 64-bit. If you'd rather not, then stick with a 2GB DDR2-800 kit for $80.
The 8800GTS 640MB is fine if you have a 20 or 22" LCD and want to play with high detail. If you don't care for detail or have a smaller LCD, then the 320MB version would suffice. Keep in mind, the newer NVIDIA cards are coming out soon, so you may want to pickup a holdover card and upgrade when the new cards come out.
Definately upgrade that PSU. Go with a Corsair 520W or 620W.
If you want to play DX10 games in DX10 mode, you'll need Vista. However, most new games will be compatible with DX9 hardware, so you can still play newer games with older cards. If you already have XP, stick with it for now unless you want to take the Vista plunge now. Vista has matured a lot over the past 8 months, but some people are still waiting for SP1 and more DX10 games.
Are those the only parts you need? What's included in that $1200 budget, and what parts, other than the CPU, have you decided on so far? Show us your list.
Here are the parts that I would like to "recycle" from my old system and use in my new system:
Case-Thermaltake Tsunami dream
HDD-WD raptor 36gb 10,000rpm (Sata), WD 320gb 7200rpm (Sata)
Sound-Audigy 2 ZS PCI
DVD-RW LITE-ON SOHW-1693S (IDE)
No-name DVD drive (IDE)
HP 23" 2335 monitor
Keyboard, mouse, speakers (I got this covered)
Here is the list of new parts that will be used in conjunction with the above parts:
EVGA 256-P2-N755-AR GeForce 8600GT 256MB 128-bit GDDR3 PCI Express x16 SLI Supported Superclocked Video Card - $134
Rosewill RX850-S-B 850W SLI Ready,APFC,ATX12V v2.2/EPS12V v2.91 Power Supply - $169
Crucial Ballistix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model BL2KIT12864AA1065 - $154
GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ATX Intel Motherboard - $99
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Processor Model BX80562Q6600 - $279
When suggesting feedback please consider the following:
Budget under $1,000
I will wait for next generation video cards when games like Crysis come out
I am not a heavy overclocker but would not mind a slight performance boost
System will be used mainly for HD video editing
The total from newegg is $839 for the new parts plus tax and shipping.
Am I overlooking anything?
Thanks for any feedback or suggestions.
JLove:D
GPU: If you are getting a new one when the next gen ones are realeased then why aren't you getting a cheaper one for now?
PSU: Look for the Corsair 620w
RAM: Look for something cheaper, ie $80-90
Also consider the Tuniq Tower 120 for OC'ing a Quad, (even if you decide not to a better HSF will be a good idea.
set up looks ok, but get a good solid power supply. The corsair unit is good, or you could look into a PCPC 750 Silencer.
What about sound?
Ditch the Rosewill PSU. Go for a better quality one, like the Corsair 620W from clubit.com, zipzoomfly.com, or buy.com (newegg's price is too high). You don't need an 850W PSU.
Do you plan on going SLI in the future? Your 1900x1200 resolution is a lot for a single card solution, but still doable. A current GTX or Ultra would be ideal, if not going with an SLI setup. So, the replacements for those high end cards should be in Q1'08. If you do plan on going SLI (and spending ~$1k for the vidcards alone), then go with at least a 680i SLI LT board (the eVGA 680i SLI A1 is ideal).
Drop the Ballistix down to the DDR2-800 kit instead. Thats all you really need with a Q6600:
(CPU Multiplier) x [Base FSB speed] = CPU Clock speed
2 x [Base FSB speed] = RAM speed
4 x [Base FSB speed] = Effective FSB speed
On Intel platforms, running the RAM higher than a 1:1 ratio with the CPU is useless. Keep it linked at 1:1:
Q6600: 9 * 266 = 2.4Ghz, DDR2-533 << STOCK speeds
Q6600: 9 * 333 = 3.0Ghz, DDR2-667 << Nice/Easy OC
Q6600: 9 * 378 = 3.4Ghz, DDR2-756 << Good OC, near max for B3 stepping
Q6600: 9 * 400 = 3.6Ghz, DDR2-800 << Great OC, near max for G0 stepping
Go for a Tuniq Tower 120 or Thermalright Ultra 120 eXtreme + S-Flex fan fan for a good OC.
If you want to save money on the board and don't need legacy ports:
$89 - ABIT IP35-E LGA 775 Intel P35 ($20 MIR)
