Hey everyone..
New here, last time I OC'd anything it was a Celeron 300A on some a-bit board.. It's been a while.. the whole concept has been lost on me.. My current athlon t-bird 1.4 is getting a lil old.. plus my HD was dying so I figured.. fawk it.. i'll build a new PC..
Here's what I'm getting:
Abit NF7 Nforce 2 Audio Lan ATA133
2x CORSAIR DDR400 PC3200 512MB
AMD ATHLON 2500+ Mobile
Vantec VA4-C7040 HSF
Antec Performance II SX635BII case w/350W power supply
ATI/Sapphire Radeon 9600 256M DDR
Seagate 120GB 7200RPM 8MB
What kinda OC results can I expect with this setup .. air cooling only.. Also.. could someone explain to me raising the multiplier / core / voltage...
How bout OC'n memory as well??
Probably be easiest to throw some settings that work .. I can try with those and play around after that...
Does it make a diff when you OC?? Should I do it before / after I install windows??
Anyways, lookin aroun on this board, there's obviously tons of knowledgable people, any info / help you can provide will be appreciated..
thanks..
-Tawheed
thanks..
-Tawheed
