Need lighting advice
Tehbolt
So, I have a 22inch westhinghouse wall mounted, and for what ever reason its DESTROYing my eyes. They hurt really bad. I was wondering if adding any back lighting to it would help? if so whats a cheap way to go about it.
Thanks
Thanks
Cheap backlighting can be acheaved with a cheap desklamp from office depot. Just aim it at the cealing. It is better if you have two, one on either side or behing you.
Also, I would suggest you ditch the wall mount and put it back on it's stand so you can experiment with viewing distance. I personally think that 22 in. is too small for wall mounting, but this can very a lot from one persion to another.
Best of luck with it.
Dave
