** Need info in Loop Routing **
M a d c o w
Routing as follows:
** Loop Sequence **
1. Iandh SteathRes 225 Multi-Option Reservoir > Top
2. Bitspower Black Sparkle Dress Kit & Top > Bottom of IANDH
3. EK-Waterblocks EK-BAY SPIN Reservoir - Acetal
4. RAdiator / XSPC RX360 - 3x120mm Radiator Rev. 2 >
5. CPU >
6. GPU >
Also with all this connected not sure but the impeller in the res barely spinning
and in youtube videos that is connected in there loop spins alot faster. What are your thought and recommendation in set up
Is your pump getting water? If it is nothing you can do really but just let it spin and push the air out.
Make sure the pump is getting 12v not 5v.
Should go Res > Pump > whatever. Make sure that pump is not dry, or you will kill it quickly.
Nice pump I'm still rocking an old D5 what is it maybe 5 years old now...
Picture might help us identify your issue.
Yeah loop order doesnt really matter, just res > pump like posted above.
Flip the case on its side, upside down, etc. There can be an air bubble that is the blockage somewhere in the loop, shaking, tapping, and inverting the loop can help fix it.
