Need helping finding a switch
BigTaf
Im currently trying to put together my own 7v/off/12v fanbus. However im having a hard time finding switches that will fit my case. I have a silverstone tj05 which kind of looks like the wavemaster and because of the door i cant use the common DTDP Toggle Switches.
Ive been looking for something like this
http://www.adpmods.com/xcart/catalog/product_917_Round_Rocker_Switch__Black.html
but of course DTDP
anyone know where i can buy something like that in canada?
I tried radioshack and canadian tire already
also my CCFL lights have a quick connect convered in a blue shroud on the switch
anyone know where i can find these as well?
any help is appreciated
you want rocker switches? i bought mine at radioshack for like 4 bucks, but like you said you already went there weird because thats where i got mine. maybe if you check back there in a week they might get a new shipment
I had the same problem once, damn those doors...
Anyway, I used these switches. They aren't rocker switches, but they were small enough to fit behind the door.
Here are a few dpdt rockers @ radioshack.com
Rocker 1
Rocker 2
Could also just get a standard rat shack toggle switch and dremel it to spec.
Are there toggle switches with 7v/off/12v? or how every order it is. Im going to have case fan switches and all and i was just gonig to get on/off. Also could you direct me towards whereabouts i would look to find these?
