Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
On Newegg, when i look at the cas latency it has somethin at the end tat says 1t or t1. What does that stand for and is ram better with t1 or 1t or without it?
Some Manufacters dont bother to put it in their specs probably. All DDR will run 1T at least on Intel motherboards for sure. You may wanna check with the "other side" and see if its the same for AMD cause i dont know for sure on that lol.
