Diablo2K
- Aug 10, 2000
My current setup is:
Linksys WRT54GS Running DD-WRT
MSI US54SE USB Network adapter
Trendnet USB Network adapter with Hotspot detector.
Router and computers on seperate floors about 50ft apart.
I am losing packets. My computer is getting a signal of about 60, (4 bars with the windows login app) the router says it is recieving a signal of 66 with signal quality of 32%. I am guessing the low signal quality is causing alot of the problems. I cant even play a single round of BF2142 without gettting kicked right away for "Losing Key Packets"
when I run Pingplotter I do see dropped packets, less than 1% over about an hour. the packets I am losing seem to be from servers further down the route, I am not losing packets between the router and computer. but at steps 5 and higher.
I am thinking about getting:
Linksys WRT54GX Router
Linksys WMP54GX wireless NIC
I don't want to run DD-WRT anymore so compatibly with that aint an issue.
I don't need a super fast setup, I only have a 8meg cable connection and dont transfer files from computer to computer. I just need a good clean signal.
Also is there extansion cables for the antenna on the WMP54GX, I am willing to spend some time finding the best location for the antenna but I need something longer than the stock cable.
Is there any good aftermarket upgrade Antenna that is cheaper than the linksys brand, the linksys ones cost as much a a whole router.
I am going to be spending $140 for the Router and NIC and don't want to have to spend any more than I have to for a good quality signal.
