need help with Epox 8RDA31
Dytralis
just out of curiosity...
I just received and installed an 8RDA31 board and it's stalling on post at dectecting the IDE drives.
by the time it finally gets to booting the hard disk, it fails to read it
the error code on the display is "FF"
I've tried all the common "fixes" to try to get it to work. (eg. flashed the bios, reset the bios, took out the battery reseeded the CPU) and still nothing.
does anyone know a fix or am I going to have to RMA the board?
As I look down at my 8RDA running a Barton 2500+ at 3200+ speeds, I too see that little code "FF", and things are running fine. I don't know where the idea came from that "FF" was something bad. In the back of the EPoX manual it simply says, "Boot attempt."
My first suggestion to solve your problem is, if you are using Western Digital hard disks, play around with the jumpers. Ever since I started using WDs back in 1993, they have been finicky about whether they are master, slave, or cable select, and it also depends on the particular HD its sharing a channel with. Basically, WDs do not play well with others. If you are using WD, try to boot with just one HD, and set the jumper to cable select, then try mixing it up if that doesn't work.
Second, go into the BIOS immediately after POST and make sure the IDE settings aren't trying to recognize your HD as a CD-ROM or something. Just choose "auto select" for a starter.
Good luck, and post your results or more info if this didn't help.
yea, my 8RDA+ also has "FF" i think that means "Fine, Fast" ionno but its NOT ur mobo that is corrupt
