Ok so I have an old Compaq (yes they suck). I recently bought a new case for a computer I was working on, but being a noob, bought an el cheapo. So since I plan on buying a different case for my new computer I figured I'd move the old Compaq into the cheap case since I don't like the Compaq case.
But adding to the suck, Compaq mounted the CPU on a daughter board which is held in place by a few screws on the inside of the case. That and the Mobo and Power supply are not standard 20-pin connectors.
Long story short, I was thinking about buying a new Mobo and CPU on the lower end of the budget and recycling the other components out of the Compaq. Any suggestions?
The Compaq was a PII - 450MHz so any type of upgrade will be noticed. I plan on installing XP and using it as my surfing/banking/older games computer while I work on my new rig. Can I get a decent CPU/Mobo for say under $200 total?
Thanks in advance.
Thanks in advance.
